morgandlm
Some advice needed please. I have just re-commissioned my old Bukh DV10 after the winter lay-up. One of the winter jobs had included removing the high pressure pipe to the injector (I had renewed the exhaust injection bend) so I knew a thorough bleeding would be required. Despite doing the usual bleed through of diesel and loads of hand and electric cranking, I had the devil of a job to get the engine to run.
The bottom line here is that I am wondering if the fuel lift pump is not working. Access to this is tricky (as are nearly all jobs on this engine) but can it be dismantled in situ? Am I right to think that the engine will work if there is a positive head from the tank even if the lift pump is u/s? I cannot think of why else the engine proved so difficult to start.
Any advice gratefully received.
David Morgan
David Morgan
