Nicholas123
N/A
Anybody know where they are? I tried to locate them using my manual & owners handbook & all I could identify is the zinc anode plug,are there any more?
You might find these documents useful. I uploaded them to my website so that a friend could look through them. I'll probably be deleting them in a few weeks as I'm a little short of space. Workshop & spare part manuals for DV10 & DV20 (both docs. over 300 pages)
Port side forward, there is a sea water drain bolt, suprisingly high up the engine, but the coolant doesn't cool anything lower than the pistons....
There are 3 on the DV20 and you already have 2 out of 3
1) Pencil anode plug at top rear beside the exhaust
2) Block drain on port side just aft of the starter motor
3) Underneath the exhaust manifold at the very back (Huge thing compared to other 2 above)
http://www.mistroma.pwp.blueyonder.co.uk/MistromaOriginal/Bukh_DV10_DV20_Workshop_Manual.pdf
http://www.mistroma.pwp.blueyonder.co.uk/MistromaOriginal/Bukh_DV10_DV20_Spare_Parts_List.pdf
Is the DV20 the same as the DV10? The starter motor is on the starboard side on the DV10 so I am a little confused.
I shall look for the one you have identified as "(3)."
Thanks very much for the workshop manual & parts list.I'm sure they will come in very useful but I hope I never have to use them![]()
There are photos of the drain point on the DV20 at http://coxengineering.sharepoint.com/Pages/Calorifier.aspx On the port side I think. The manual seems to say that they are the same on the DV10
There, fixed that for you - Starboard Side unless one has fitted the engine arse about faceThere are photos of the drain point on the DV20 at http://coxengineering.sharepoint.com/Pages/Calorifier.aspx On the starboard side I think. The manual seems to say that they are the same on the DV10
Just been down my boat & I searched all round the block & I could only find the zinc anode brass bung......I think that the only one that exists.
Look again then Nicholas , forget all the confusion with DV20.
I have a DV10. and there IS a drain plug on the port side (assuming your installation is flywheel fwd), quite high up the engine. Use a lamp and mirror if you need to, it IS there.
Looked particularly for that one & could'nt see any sign of it.....& my boat has got exceptional access so no mirror needed........Could you identify EXACTLY where it is?
will do but I cant get to the boat till tomorrow eve, I will try to give dims from c/l of the flywheel.
not been there yet...
Does this pic help, from P 4 of the spare parts manual...?
shows items 50, 51 screw & seal but doesn't say the size. I recall the bolthead is about 14mm a/f
I was down my boat this morning chewi & I scoured that area without seeing anything that looked remotely like a bung.That area on your drawing is behind the water pump & before a fuel pump/filter thing so I will look again tomorrow morning but I can't imagine I missed it.
