Are they the original/original spec screws? They look like stainess? What are the markings on the heads? Agree with Vyv that they were all loose prior to the point of failure so I beleive they were not tightened correctly and maybe the wrong grade of screw.I have just had a bukh dv24 flywheel come off , very unsettling .
Of the six bolts five gave sheared.
Would the panel agree this points to one bolt unscrewing then overloading the other five ?
That looks like fatigue to me although I would like close-up photos of the fracture faces to be certain. You can compare them with ones on my website for further info. Fatigue
If so the cause is that all were loose, one of them enough that it unscrewed itself totally
All loose I would think. Unless they are old reused machine screws or cheap replacements and not the proper Unbrako ones. They are supposed to be one time screws.
When I said unsettling I was using understatement , I am still investigating and in contact with the engine supplier who is assisting, they also want to make sure it is not a bad batch of boltsUnsettling?
I'm surprised, and pleased, that you are here asking advice on why it happened, rather than reporting the major damage and injury that such a flywheel coming might easily have caused.
That was my understanding, too - that new proper Unbrako screws are specified for each time the flywheel is refitted.
I was once aboard a yacht with one of these engines witnessing a test. Something did not seem right with the flywheel so I signalled to the owner to stop the engine Jast as he responded the flywheel separated from the crankshaft and came to rest cradled on the bearers. Examination showed that the crankshaft was slightly damaged and the wrong bolts had been used. The small dimensions of the flywheel to crankshaft connection requires that everything is correct and perfect. The correct bolts must be used as I fervor bolts can not be torqued to the requir3d setting. Also check the nose of the crankshaft is undamaged so ensuring the flywheel is running true.I have just had a bukh dv24 flywheel come off , very unsettling .
I concur, they were loose as is demonstrated by the damage to the threaded holes; possibly they weren't torqued correctly or possibly no thread lock applied, allowing the vibration to slacken themThat looks like fatigue to me although I would like close-up photos of the fracture faces to be certain. You can compare them with ones on my website for further info. Fatigue
Is this a new(new or at least new to you) engine from a company reselling lifeboat engines? Or had the flywheel been off for some maintenance?When I said unsettling I was using understatement , I am still investigating and in contact with the engine supplier who is assisting, they also want to make sure it is not a bad batch of bolts
I'll save Vyv the trouble... here is the link to his very useful website Cox EngineeringI'm learning lots from this thread about fywheel attachment/detachment .
I'd be inclined to listen to vyv cox above. He is often on here talking sense about stuff like this.
If I remember rightly he has a very informative website with a lot of really useful techinical info
If we're lucky he might come back with a link.
His book, "Metals in boats" ( https://www.amazon.co.uk/Metals-Boats-Vyv-Cox/dp/1785002627/ref=asc_df_1785002627) is an excellent resource, too.I'll save Vyv the trouble... here is the link to his very useful website Cox Engineering
Yes, engine had run for about 1.5 hours about 20 mins idle and the rest at 3/4 throttle . I had not touched the flywheel since I had the engine.Is this a new(new or at least new to you) engine from a company reselling lifeboat engines? Or had the flywheel been off for some maintenance?
