morgandlm
I know that this has been a popular (frequent?) topic but I could not find a response to match my current issue . I have a raw water cooled 34 year old Bukh DV10 in my Sadler 26 and although noisy and tricky to work on it has been a reliable engine. I am in the process of overhauling the cooling system again and this time will also give the cooling system a chemical flush. On dismantling the thermostat housing I found evidence of black carbon build up just inside the port that goes off to the exhaust injection bend. This indicates to me that presumably on start up, before the water flow becomes established some exhaust pushes its way back into the thermostat. Two years ago I did have an impeller failure that lead to an overheat alarm that I was quickly able to resolve. Might this be when the carbon build occurred or have others found such a problem in an otherwise normal engine? I expected to find lime build up - not carbon. Although the engine does not overheat perhaps the water flow rate is too low as well thus aggravating the problem. Any shared experience will be very welcome.
Finally has anyone found a good way to remove the cooling water injection tube/flange at the front of the engine that is tucked in behind the flywheel. Is there a trick?
Thanks for any advice
David Morgan
David Morgan
