westerlylad
Active Member
Another Bukh question if you don't mind chaps. When I switch on the ignition, before starting, I get the amp and oil pressure lights, as expected, and on starting, these go out, also as expected. What I don't understand is, looking at the wiring diagram, I'd have thought that the acoustic alarm would sound, as well as the amp and oil pressure lights coming on, when the ignition is switched on, and that the alarm would stop, as well as the lights going out, on starting.
Am I correct in my assumption? Obviously, I would expect the alarm to sound, along with a warning light, if I lost oil pressure or alternator output, but what about the acoustic alarm on switching on the ignition?
Can anyone confirm please?
