Lutra
New Member
Hi, I have a 1980s Bukh 36 gearbox attached to a saildrive. The engine is a fairly new Beta 38. Going from forward to neutral is no problem, but finding neutral from reverse is difficult. When the gear selector clicks into the neutral position, the boat remains in reverse. The only way to be certain to get to neutral is to go into forward, and then back to neutral - I don't suppose this is doing the gearbox much good. It also makes close quarter manoeuvring a bit nerve-racking especially as the Kiwi prop bites quickly and gets the boat going backwards very rapidly.
The cable and selector mechanism seems fine. I have checked the alignment of the cable. It lies at the right position when the selector and gear lever on the gearbox are in neutral.
I was hoping for some suggestions of things to try. I do actually have an even older Bukh gearbox. I'm not sure what condition it is in, and whether my mechanical skills are up to swapping it to test it. But maybe giving it a try, or more likely getting a mechanic to swap it might be my best option? Grateful for any thoughts.
