VMALLOWS
I need to replace the Stop Solenoid on my BUKH, and find the BUKH list price of £120 +vat just laughable.
Does anyone know if this type of solenoid is used in automotive applications, and therefore might be available from breakers? (unlike most car solenoids, it activates to stop the engine, rather than the other way around).
It is in fact a BOSCH item, P/N 0330 101 024 according to the workshop manual (suspicious of the 024, since it is a 12v item).
Has anyone opened one up succesfuly so as to rewind? (looks like it will be necessary to cut/grind the crimped-over outer end of the casing to gain access).
Incidentaly, reason for the burn-out was failure of the rather fiendish alarm system that relies on the oil pressure switch to determine the engine has stopped and sound the alarm..........what's wrong with putting up with an alarm for the few seconds it takes to stop the engine!!!.....will certainly be modifying if/when solenoid repaired.
Failing a solution to the solenoid, it'll be a Bowden-type cable to do the job by hand!
