chriscallender
Hi
Yesterday when I was dropping someone off at Gunwarf Quays my usually reliable Bukh 20 cut out when I went into neutral in preparation for going astern, causing me to "arrive" at the pontoon rather faster than I had been planning - no harm/damage done though.
The engine restarted fine, and idled OK so I decided to head back to my mooring. On the way there I decided I better see whether the engine was OK, so went to neutral and it cut out again. Again, started instantly without any trouble. So I picked up the mooring very slowly and cautiously - this time the engine kept running fine, so when I was safely tied up I went forwards and astern and played around a lot with the throttle, not able to make it fail.
The other thing that I have always noticed about this engine, and it seemed even worse when it was having the problems yesterday was that it is very slow to pick up revs and respond to the throttle. I believe some part of that to be due to the prop - its definitely overpropped with a 16x13 prop (on a Seal 28) when most others seem to go with 16x10. So that was on the plan to be repitched - handling is a bit of a sod when you can't get the revs on quickly. Now though I'm wondering if there is a contribution to this problem from the engine as well, as it definitely seemed worse yesterday afternoon.
Both fuel filters were changed at the start of the season and the fuel in the bowl appears to be clean. Air filter was also cleaned then - but I haven't checked it recently. The fuel tank was nearly completely full, so I shouldn't have sucked any crap from the tank up - although we had come in from a fairly brisk sail and it was probably stirred up a good bit.
I plan to replace the primary fuel filter now as a precaution, and if its dirty I'll also replace the fine filter. I wondered if anyone has any ideas about what is going on with the engine -there is a paranoid part of me that is worried about it being something serious now - think I'd better have an engine servicing/maintenance day over the bank holiday weekend :-(
Any ideas? Could it be that I am getting a bit of air in the fuel lines somewhere?
Chris
Chris
