RobBrown
My boat wil be out on the hard for longer than usual 4 weeks this winter, so some opportunity for working on the engine. This is a 28 yo Bukh DV 20. She starts OK ish (can be a bit stubborn when cold even with the air intake preheat). Once running, is absolutley fine, but recently getting some black smoke on start up only, but also if run at full revs ( c.3-3.1 K). Fine in between, but is obviously starting to use a fair bit of oil on running ( topping up a pint or so 4 or 5 times a season), so I am assuming problem is likely to be with cylinders, pistons & rings. Spent a fair bit a couple of years ago on a professional head & valves recon ( as could leave engine in situ). All other elements/peripherals & ancillaries seem fine.
Any thoughts on what further work could/should I think about getting done to try & resolve this problem cost effectively and generally keeping the old gal up to snuff? i.e. without getting any where near to the level of total costs where a replacement recon unit looks competitive (seen some on Boats & Outboards for around £2.5K). Not able to do complex engine work myself, tho I can pass over a spanner!
Rob
Rob
