Captain Coochie
I bought the plans from Selway Fisher a while ago and have finally decided to build a model of the boat first rather than messing up lots of expensive materials . Glad i did as its not as easy as i thought .
I have a few things dont ring true to me as i follow the plans so if anyone can put me right id be very thankfull .
1 . The frames and moulds are plywood then strengthened with timber ? Is this normal ?
2. If the frames and moulds are plywood why do the plans say cut rebates in the Hog to take the frames and moulds , wouldnt it be better to cut the frames and moulds around the Hog to keep max structure to the Hog ?
3 Is it normal to have 10 sash cramps holding everything together then as you put the 11th one on they all fall off ! ?
