seanfoster
Hi All,
I'm coming towards the end of my complete refurbishment on my Dufour 1800 and I'm turning my attention to the onboard gas system.
Unbelievably, the original Dufour setup consisted of a two burner hob positioned over a cabinet which contained the gas bottle!
I've since installed a cooker, but unfortunately there isn't a gas locker in the cockpit, Therefore I'm going to build one in towards the rear of the cockpit seating.
My plan is to cut a hole into the seat area and install an inspection hatch, this is the one I'm intending to use: http://www.force4.co.uk/department/...-cutout-265mm-opening-240mm.html#.VTYE8JP4J8E
It has a 240mm opening which it the exact size of a 4.5kg Calor bottle.
I will then build a suitable box from 18mm marine ply and seal it to the underside of the cockpit seat area (supporting with some timber supports), and drain it with flexible hose to an above water through hull fitting.
Can anyone suggest how to line the ply to make it lpg tight? I'm thinking of coating each side with epoxy.
Any suggestions would be appreciated!
