Buccaneer 400 series connectors
rogerthebodger
3 Nov 2001
I have been trying to remove the pins from the above type connector due to the breakage of some wires but the stupid plastic pin remover supplied by Bulgin in just not up to the job.
Does anyone know where I could get a pin remover made of metal that does no break as you insert it into the connector.
due to my location mail order would be best.
I used these connectors for my Plotter in the cockpit.
Surely the small cost of these connectors, is it not worth cannibalising your damaged one and replacing with another rather than going to the expense of a tool you will probably never use again after the repair was done?
The cost of replacement where you are may be small but after the shipping costs, import duty, VAT and the very large markup the local suppliers add on they are not cheap where I am.
