BigCheese338
Hi all! This is my first post so be gentle!
We own a 30ft, Norfolk Broads, gaff rigged sailing cruiser with GRP hull, fin keel and fitted with a Yanmar 1GM10 in the bows.
The prop is shaft-mounted behind a cutlass bearing half way down the narrow trailing edge of the keel, with the stern tube inside that. The current one is virtually useless astern and if you've sailed on the Broads, you will know how important it is to be able to manoeuvre safely in confined spaces. This is compounded by the keel stalling at relatively high speeds, especially in astern.
Because we often sail in weedy areas, a folding (as opposed to feathering) prop is a must.
The best information I’ve found is in the 2009 YM article, reporting on comparative tests between various folding and feathering props. Along with other research, I’ve concluded the Flexofold 2 blade is probably the best choice. While Bruntons have a good reputation locally with their feathering Autoprop, their Varifold 2 blade came out badly on astern performance during those tests. However, they are now 13 years old and it’s quite possible improvements have been made since, or possibly it was not well matched to the boat / engine.
So, the reason for all this tedium is to ask whether anyone has relatively recent experience of either of these props. I would be most grateful if you could share it with me if so. There is so little independent data with which to make a decision, so any information will be gratefully received.
Thanking you in advance
