scr0che
Brand new Bruntons H5 Auto prop fitted, but when the power hits 1800rpm it makes a whining/grinding noise in both forward and astern. Anyone have any knowledge on this kind of issue? I'm chasing Bruntons but not getting anything back as yet.
We took the boat back out of the water to check the installation, all good. 2 of the 3 blades 'flopped' down when raised, rotating 90 degrees, not the full 180 - maybe just a bedding in issue through use? The 3rd blade did not rotate when let go at all, so re-greased all blades and worked the grease in for a while to the point is started to behave like the other 2 blades - all 3 were full of grease anyway. Noticed in ~20 degrees of all the blades 360 degree arc a 'scrape/grind' noise, minor but there - is this normal? Engineer identified on 2 of the blades when turned no vibration on the shaft, but the third one did seem to vibrate somewhat (by placing a finger on the shaft whilst rotating manually), very minimal. Bearing issue? Prop alignment/fairing issue? This is a new brand new prop!!!
We only hear this at 1800rpm, that's the real odd thing about it, move up or down from that, forward or astern, no noise at all. Engine is a volvo MD22A on a HR36, gear ratio measured in the yard at 2.3 to 1, max rpm 4000. On a test run up the river, prop performed really well power wise in both forward and astern.
Any advice much appreciated, I'm still trying to get support from Bruntons.
