sailaboutvic
I will be looking at stripping my auto prop next spring to check it out , ( 4 years old ) this is some thing I not done before other then clean and greases and I will be doing this in North Africa so I need to take what every I need with me as I won't be able to import parts .
My mine concern is any special tools needed ,
it seen there a lever tool with two pins needed to remove the outer hub , at any other time I could probably make it but being stuck out in the middle of nowhere best to buy one even does £27 for a flat metal with two pins it a rip off .
as anyone else service this prop and was there any other special tool needed ?
Any advice on any parts they found worn ? Did you buy from Bruntons or from bearing supplies?
