chrismac7
New Member
Has anybody else had this . problem its very hard to find information about the bearings . It would appear that there is a nylon bearing and a ball bearing in the bottom but is there anything in the tube to the cockpit tiller
When you say ball bearing in the bottom do you mean in the skeg below the rudder? This is not a good idea as water will get in and cause seizure!Has anybody else had this . problem its very hard to find information about the bearings . It would appear that there is a nylon bearing and a ball bearing in the bottom but is there anything in the tube to the cockpit tiller
It must be very difficult to prevent corrosion problems with a submerged bearing. or does the post rest on a large single ball? Where does the rudder post split in two?The plans for the steel, and wood version show a nlon insert with the post resting on a ball bearing. This is in the skeg below the rudder . These boats were made by humber boats.Bruce roberts never designed for grp so infomatio n is not available.
