machone
Welders are welding like mad - we're under time(it's money!) pressure. A slow steel yacht with a low hp highish tq engine and big prop. It has a shaft through the hull stuffed and remotely greased. This worked well but leaked a little and the steel in the hull is showing signs of wear - flaring. There were some funny noises on the last trip before laying up.
I'm thinking of replacing the old system with a Vetus(Volvo) water lubed shaft. This comes with a bronze stern tube. What I am worried about is the galvanic corrosion between the tube and the steel - is there an effective way to isolate the parts and what is best? I don't want to coat the bronze with anything that will act as a wick.
Also, from anybody who has done it, is it worth the swap?
Advice welcome.
Advice welcome.
