Bronze Rod Supplier (for rebuilding wooden blocks)
fluffc
31 Dec 2002
Southampton
Hi People
I am trying to source about 18" of 3.5mm bronze rod, to hold together the cheeks of a wooden block i've rebuilt.
Anyone know of stockists with reasonable delivery charge, or does anyone have a little bit lying around??
Or can anyone suggest an alternative method. The cheeks are glued together, but need some sort of secondary mechanical fixing.
Thank you all /forums/images/graemlins/smile.gif
" Or can anyone suggest an alternative method. "
We used to use copper boat nails and roves , might be easier to find than 3.5mm rod.
Bronze is the thing you want. You will still be able to peen over the ends if you want. You wont gte it in metric sizes though.
I have oredered form Anglia before and from a company called GTC. GTC have a good web site and are a bit cheaper and more helpful
Regards
Small quantities of non-ferrous and stainless rod, bar, angle and other sections are available from a company called:
M-Machine, 01325 381300, in Darlington.
They supply mainly to model engineers, and sell a huge range of metals by the foot, or in the larger sizes, by the inch.
No website, but they will send you a product list if you give them a ring. P&P very reasonable too.
For example they list 5/32" bronze rod at £1.86 / ft. + p+p
