AAF
Active Member
Was out in Weymouth bay this afternoon in my Broom 39 (VP D4 260HP) and sticking close to the Portland harbour wall and just pootling along as it was certainly lumpy any further out. Suddenly a horrible burning smell with smoke and mist coming up the stairwell into the cockpit from the cabin.
More than slightly worrying....
Took up the cabin floor and diagnosed it was the starboard engine so shut it down. Further inspection revealed litres of diesel in the bilge under the engine.
Started to trace the fuel lines and the engine areas smeared with diesel and concluded that the problem was under the engine cover so removed that. Nothing obvious but when the engine was (briefly) turned over there was a leak (i.e. spurting atomised diesel) from what I think is the diesel return line. There is a chamber on top of the block that has an inlet pipe, 4 pipes leading to each of the cylinders and one heading aft and then down through various engine bits so I am assuming it is the return line. There is also a pipe supporting clamp missing from the run of this pipe so a possible cause of failure is vibration. (We actually found a part of a clamp in the bilges during the survey in July last year before I bought the vessel but could not identify from where it came. Now I know!)
I am not sure of the flash point of diesel but looking back was I lucky not to catch fire?
Back to the main question. Do the forum engine experts consider that the pipe failure is very likely this clamp bracket absence and replacement of this failing part is all that is required? Or should I test and/or replace all the fuel pipework as once one of them fails all the others are suspect? What about the port engine that has done a similar 435 engine hours - is that also suspect? Your thoughts welcome.
Also any recommendations as to how to clear up the diesel in the bilge? I am sure I am not the first with this opportunity.
I am supposed to be taking my twin daughters for a birthday spin around the bay on Saturday, but that looks unlikely unless I can get the replacement part tomorrow. Any recommendations as to where to go to source the part?
To conclude the story we made it back to my Weymouth marina berth on port engine alone and without hitting anything. I had the marina staff standing by to nudge if necessary as it was very gusty in the harbour. Thank goodness for the speed of "extremely dead slow" and the bow thruster. It would not have been impact free this afternoon were it not for that piece of boat equipment.
