Andrew G
Brief "No Fix" from GPS' NMEA Converted to SeaTalk(1) for a Raymarine Chartplotter
I had raised this issue on two other threads but am now trying to consolidate discussion to this new one (sorry if I have caused confusion).
I infrequently get "No Fix" alarms when there are plenty of strong satellite signals.
I am feeding my GPS’ NMEA output into the “NMEA In” of a Raymarine E85001, which then converts this to SeaTalk(1) (via the E85001’s “SeaTalk out”) which is then connected to the main SeaTalk bus. I input the SeaTalk, from the ST bus, to my Raymarine SL631 Chartplotter. (The +/- 12V for the E85001 is taken from the main SeaTalk bus' + & -).
About once an hour (or less frequently) the chartplotter briefly reports a “No Fix” alarm, even when there are plenty of strong satellites (I have been logging the GPS’ NMEA via HyperTerminal and can “read” the sentences). The CP and instruments also briefly show SoG = “- - -“.
I noticed that it happened before I purchased the E85001 and fed the GPS’ NMEA directly to the “NMEA In” of the chartplotter (I’d prefer to not have to have the CP turned on just to see SoG on my instruments).
I suspect there is an issue on the ST bus as I can’t replicate it at home (ie with the E85001, the Chartplotter with ST, and GPS). On the boat the SeaTalk bus has depth, wind, temperature, fluxgate compass and, when active, Autopilot data – but it also happens with/without AP on).
The GPS is a new modern 50 channel unit and my problem has occurred when receiving GGA/GLL/RMC/GSV/GSA/VTG/ZDA messages on one setting, or RMC/GSV/GSA messages on another – I have not yet tried the RMC-only setting as this defeats the purpose of having an expensive device acting as a cheep and cheerful one).
One quirk is that the GPS’ NMEA output (and hence the Chartplotter) reports a Differential Fix even though there are no Differential signals around.
The supplier has been quite good (they have “never seen this”) and has sent me another GPS antenna in case mine was at fault – it occurs with both, but only on the boat.
Any suggestions? Andrew
Nigel Mercer has queried whether there could be congestion or collision of messages on the SeaTalk bus – the old setup was with a Ray 120 which communicated similar traffic directly to the ST bus without any problems.
