Bravo3... Exhaust tube or bellow
Noldi
New Member
30 Nov 2020
Hi folk
I have a Doral 31 with 2 Merc 4.2. D-Tronic. Max speed 36 knots
I ordered a kit with bellows and seals.
There are 2 different kind of exhaust tube/bellow in the kit.
I think to reduce noise as much as possible the bellow would be better.
BUT....
Bravo Models Exhaust Preparation
IMPORTANT: When installing through the transom exhaust, it is recommended that the
exhaust bellows on the transom assembly be removed. This is necessary to avoid creating
a vacuum at the exhaust outlet in the propeller at higher boat speeds. This vacuum could
degrade propeller performance on some boats.
  • If required, remove and discard clamps and bellows from gimbal housing.
  • IMPORTANT: When installing through the propeller exhaust:
  • • With Bravo One and Bravo Two Sterndrives, an exhaust tube MAY BE INSTALLED for
  • a slight increase in performance.
  • • With most Bravo Three Sterndrive Models, an exhaust tube MAY BE INSTALLED for
  • • With a Silent Choice Exhaust System, the exhaust bellows must be removed and an
  • exhaust tube MUST BE INSTALLED.
  • With any application, installation of an exhaust tube will increase exhaust noise.
Does anyone have experience with it?
Thanks, Noldi
