garysboat
New Member
Hello.
I wonder if someone can help me please? I've a problem with the steering on my boat... its got a Bravo 3 sterndrive which obviously has power steering. The power steering isn't really working very well, and therefore its stiff to turn the wheel.
I've managed to borrow on a buy or return basis, a new pump and new piston ram... but after I've replaced both of these it still doesn't work!
I've disconnect the steering cable and with the engine running, pushed the shuttle valve in and hydraulic piston moves and hence sterndrive moves (as I thought it would)... but when I reconnect the steering cable and turn the steering wheel - it doesn't seem to work! I've noticed that the shuttle valve moves a little when I turn the wheel and maybe there is a very little boost to the steering from the piston - but only for a second, then it moves back to the centre position and hence the piston doesn't move.
The steering cable seems to have a little bit of play in it - but not a lot really about 1 cm.... would this cause the issue? I can't think of anything else that could be causing it! Do all steering cables have some play in them?
Any help would be appreciated please, as I have now run out of ideas.
Many thanks
Many thanks
