Bravo 3 rear prop nut....
scadding
22 Sep 2009
This afternoon I decided to remove the props from my bravo 3 drives.....another infamous 5 minute job!!
The port drive was easy and the duo props were removed in a matter of minutes.
The starboard outdrive was a different matter..... Having applied loads of WD40 and as much pressure as I think safe to my breaker bar I could still not get the rear prop nut to turn.
Has anyone else experienced difficulties with Bravo 3 prop nuts and if so can you please tell me how it was resolved.
I am a little concerend about applying to much pressure in case something fails..... Would that be possible?
All suggestions would be gratefully received.
Thanks in advance......
