JamesTT
Has anyone experience of wear in the outer section of a Bravo 3 transom assembly?
The boat is 5 years old, done 350 hours, is out of the water for 7 months each year stored dry and has been serviced and inspected in accordance with Mercruiser schedules.
Some pictures attached, a hole has now been cut in the outer casing to gain access to the tiller/ steering pin connection and investigate play in the leg and a water leak.
Just visible through the hole is a raised ring of the casting where the top of the vertical pin/bolt seats that then joins to the tiller as it protrudes through the transom, the casting is worn and rough preventing a proper seal, the drive has dropped, the bushes on the lower section were missing upon lifting the boat causing the excessive play and the leak.
The boat has completed 18 hours this season since March and a full service of engine and leg over winter including an investigation and fix of play that i reported in the steering, apparently this is a common Bravo 3 issue and was cured by drilling the side of the casing (hence the grommet visible to the right hand side of the casing) allowing access with tools to tighten the u-bolts on the tiller/pin.
I am advised that a complete transom assembly is now required and that the engine requires to be lifted out to fit the inner and outer new parts.
Any ideas as to what has caused this wear, has anyone experieced/seen it before, any advice greatly appreciated?
