dave1dpc
After many years of a stiff starboard shift last season i changed all the cables from both helm stations inc. the one to the leg and change over tray etc . No improvement so opened the leg to find the detent canister to be inoperative [stuck in] . But this should not effect the shift but to the contrary. I took the leg to a Merc dealer and after a couple of weeks picked it up to be relieved of nearly £500. No parts were changed and only a clean up of the linkage had been necessary . When i replaced the leg ive done at least 10 x2 legs over the last 20 + years] the shift was much much harder than before. almost impossible . The dealer agreed to come to the boat to check it out insitu . He agreed it was not a cable issue and took off the rear vertical panel. The shift was then was much improved but only when the detent spring was removed would the shift revert to near normal {no better than before}. He therefore suggested the spring had been added at some stage and left it out promising he would get back to me after checking the parts list. He never got back so i phoned him and he said the spring was NOT shown and to live with it . He also indicated I may receive another invoice for his time.. Ive had the boat from almost new and know for sure the canister can only work spring loaded {just google bravo outdrive canister and spring ] Any advice will be welcome before the boat gets wet again.
