Brass or bronze machine screws.
Monique
1 Feb 2010
Baleares
Hello Gang,
I've tried in vain to find the above fasteners in bezel flathead, either Philips or Common in 3.5MM X 3.0 CM. These are for door hinges aboard a Nauticat.
Here is a piccy. Can someone help?
TA as usual.
As Pete says they are countersunk machine screws.
Slotted heads are called "slotted" heads
3.5mm is an uncommon size although IIRC it's used in electrical fittings
Are you sure they are not 4BA:
Dinghyman's first eBay link has the right description, and is for the flat-headed screws you want, but the photo looks wrong - the screws aren't long enough.
As an alternative, these from Farnell are right size, flat head, look right, but are plated brass, so if you want brass heads showing you'd have to abrade them - http://uk.farnell.com/tr-fastenings/m3-530-isbrmcn100/screw-slt-csk-brass-np-m3-5x30/dp/1420058
I think its another seller that just uses one photo for every size - I spotted some 70mm ones from the same place but they had the same photo as well.
