T_S
The Ray sands! Could someone advise me the best route to take and of course tide window please? Plan to make the trip Saturday 5th September.
Cheers for that I'll take peek.Go here for the latest soundings- the date of which in case you miss it was Sept 2008!: -
http://www.crossingthethamesestuary.com/Ray Sand Download.pdf
Strongly recommend you to buy the book which is excellent and just the job for East Coaster's needs
Hi Roger, thanks for the detailed info. Tadpole has a lift keel and draws only 2' with it retracted. When I checked the tides for Southend-on-Sea the almanac listed a height of 5.6 which would get me over the Broomway. But its getting to Havingore bridge an hour before HW should I try and do this in one go! Hence why I'm looking at using the Ray sands and wether this is all do-able in one go.What do you draw? Saturday tides - sucks teeth. Not big tides. HW Burnham 2013 BST 3.8m (Range 2.8), Bradwell 2020 4.1m (Range 2.6), Walton 1931 3.3m (Range 2.0). Half tide at Burnham will only give you 2.4m of tide (2.3m at Walton). Repeats question - what do you draw? Suspect I would use the Knoll Swatchway and be in the last two hours of the tide at the Rays'n. But that suits my draught.
TS/Dave
If the weather is good, crew now lined up & we're coming with you, plan is to leave Bradwell Friday 4th, through Raysand channel & anchor in Yokesfleet Creek, out Sept 5th through Havengore at HW-ish.
IanC
