Bowthruster Remote
Croftie
19 May 2015
Last year I fitted a bowthruster to the boat. A Vetus one with one control in the wheelhouse and another at the external helm. Thought a remote may be useful at times but a fairly expensive option from Vetus. The joysticks are connected to the motor by a 4 wire cable with each joystick having an in and and out plug so you can link in a "daisy chain". Checking the Vetus circuit diagram the 2 inner pins on the plugs are 12v+ and 12v-. As you move the joystick 12v+ is supplied to one of the outer pins to energise the main relay to activate the motor in one direction or the other.
Purchased off ebay a Winch Remote Control
http://www.ebay.co.uk/itm/RECOVERY-WIRELESS-WINCH-REMOTE-CONTROL-TWIN-HANDSET-ATV-TRUCK-12V-12-VOLT-UK-/151987190991?hash=item2363247ccf:g:M3MAAOSwTuJYwmdF
Quite a simple wire up to the unused plug at the end of the chain as the remote controller has 4 wires (+ antenna) 12v+ and 12v- in. The 2 other wires output 12v+ depending on which button is pressed.
I gained a remote on a boat once as it just came with it. I would save your money. It has little value. There are better things to spend on
At several hundred for a Vetus one I would agree but the one I fitted was off Ebay designed for wireless winch control (see link) which cost £11 - not a huge amount.
Did the same thing on my targa 40. Handy if I am single handed mooring up. No need to run round like a maniac.
Evening, easily done without buying the scandalously priced Vetus remote. I made my own using a garage door remote kit from Maplin and a couple of relays. PM me and I'll send you circuit diagram and details. Cost about £20 quid all in.
Some time ago on this forum you offered to share a circuit diagram to wire a bowthruster remote control unit . If that wiring diagram is still available I'd be most grateful if I could see a copy.
I'd like to fit a remote to my Fairline Targa 37. It has a Vetus thruster, but it doesn't have the multi plug needed to fit the off the shelf kits. The joystick just operates one of 2 on-off switches under the stick.
Tony
