wonkywinch
It means the battery has 50 Amp Hour capacity. In theory, you can draw the 800 amps for 3.75 minutes before the battery was empty. In reality, lead acid cells don't work like that, so usable capacity much less.Agreed. 800CCA sounds fine. No idea what 50A means in this context.
I linked to the battery spec in my post above #3
https://www.exidegroup.com/eu/en/battery/EM1000
In the OPs case, his bow thruster will draw up to 500 amps (well within the CCA capability of the battery). The problem is the capacity is low so it drains pretty fast (see tables elsewhere for terminal voltage as a relationship of battery state of charge for a 12v lead acid battery).
His battery is too small for this purpose.
