Bow rollers
Clyde_Wanderer
15 Jun 2006
Glasgow
Still havent managed to find a supplier of rollers suitable for a bow roller, looking for one 40mm long x 35 dia.
Any help?
While on, Where can I get aluminium framing for windows, the type used in the Elizabethan 30?
Thanks, Eamonn.
Any help?
[/ QUOTE ]www.marinestore.co.uk part number DA3154-GA-037-028 (do a search on "roller" and scroll down to the bottom of the first page) or if you have access to a lathe they are easy to make out of Tufnol® or "nylon" rod.
"Artificial intelligence is no match for natural stupidity"
sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
I had the same problem. My neighbor gave me a length of tufnol rod about 2.5 inches across with a half inch hole through it. I cut off the width I needed and fitted an half inch bolt to it, the end of a bolt i fitted to a half inch electric drill. With the drill clamped firmly in a vice I ran the drill at its lower speed setting and shaped the roller with a chisel as you would when wood turning. I was surprised how easy and how well it turned out. Probably do the same with polypropylene boat trailer rollers.
