Robin
Our new to us mobo, a Birchwood TS37 from 1986 has an anchor hawse pipe that restricts anchor selection and later models had a more normal roller system bolted on deck. I want to upgrade the anchor to either a Delta, Manson or even Rocna, none of which will fit the existing set up. It would be useful to have a double roller and a means of locking the anchor in place when stowed on the roller.
What are the loads to consider, sheer or tensile and how best to plan for these in design. Windlass is a Lofrans Kobra with horizontal drum and below deck motor with plenty of free fall space for chain of which we have 60 metres of 10mm. probable anchor will be a 45lb Delta as we have had several, have confidence in it and most importantly can afford it.
Any standard rollers that might work?
