prv
Not the whole assembly, just the roller itself.
Both of Ariam's are knackered, and need replacing before I do much more anchoring. I'm going to go along to the boat tomorrow evening to measure up, but I thought I'd see whether the forum has any ideas I should incorporate or pitfalls to avoid.
The starboard one is pretty much only used for the snubber (the anchor obstructs it when stowed, so can't be used for mooring pendants). So the required profile seems pretty simple, just a roughly semi-circular dip from one side to the other. It's the port roller, where the chain goes in and out and the anchor is stowed, that's more tricky.
It was originally flat (ie, cylindrical) with a narrow groove in the centre. This is obviously designed to accommodate chain by having the vertical links fit into the groove while the horizontal ones rest on the sides. Unfortunately, the wedge-shaped profile of the Spade anchor shank has been forced down into this groove, pushing the sides of it outwards and splitting the roller apart (this is why it needs replacing, big lumps are missing and the chain jams in the gaps). I need to come up with a new profile that will carry the chain, and also fit the shank of the anchor without strain.
I can really only design this with the parts in front of me, but some questions occur:
How big a difference does roller diameter make to the effort of hauling chain; is there a minimum to avoid going below? The roller assembly has a closed top, so I can't end up with the anchor sitting significantly higher than it already does, which limits the diameter I can have.
Any reason not to just have a relatively steep-sided V form, or will chain jam in this?
Similarly, is the narrow groove design really that much better than a flat roller?
I'm going to get it made by Versatile Marine in Penryn; they can do a range of materials but I guess acetal is best?
(Or if someone can suggest a better maker I'm open to suggestions.)
Cheers,
Cheers,
