Bow ladder - how do they attach? Elan 333, Italy
brownsox
15 Jul 2004
London
Heading to Greece this year, planning to go bows-to to quays.
I (swimbo) struggle to hoist myself up these days, so we've been looking at bow ladders. They all seem to have two deep hooks at a fixed angle and it's not clear how that will fit on any given boat ... Ours is an Elan 333. It would also have to coexist with the anchor (Rocnor).
As the boat's in Italy we can't try it first.
Any advice comments or experiences very welcome.
Resolution
16 Feb 2006
Given the varying heights of quaysides in Greece I would prefer to moor up astern and use a passerelle.
However if you are determined to do it in forwards, I have a few photos taken a couple of years ago in Sweden that might help. Send me a PM with your email address and I will copy them over.
Note that most of the Swedish ladders are used to step down onto low level pontoons, not onto quaysides.
When I was working out how to create a ladder for my yacht (a US Sabre 426) I found a s/s fabricator in the Hamble who made up a s/s box that bolted onto the side of my stemhead / anchor roller fitting. The box had two holes on the top, into which we inserted the hooked over tops of the ladder posts. So we went over sideways, not fore/aft. This worked extremely well.
Good luck
Peter
Tranona
10 Nov 2007
Bow ladders are popular in Scandinavia and the Baltic in general because their marinas are box moorings going bow in and step down to pontoon. So their boats are designed with steps in pulpit and many have custom ladder arrangements. You can also buy aftermarket ladders from German and Swedish on line chandlers. However as already suggested, stern to mooring is almost universal in Greece, although some do go bows to and cope with the problems of boarding that you describe. It is possible to make a plank arrangement from the bow, but with the small space available and the problem of the anchor it is rarely convenient.
Suggest you go with the flow and when you get there look at how others have arranged bow access. There will always be a few. Who tolerate the inconvenience in return for the privacy in the cockpit.
duncan99210
29 Jul 2009
Winter in Falmouth, summer on board Rampage.
djbyrne.wordpress.com
One common way of tackling this is to have a bar which slots into the bow fairleads. This then serves as a rest for the passerelle, allowing you to step over the pulpit on to the plank and thus the quay. The other common option is a socket fixed to the hull near the bow which takes either the passerelle or a custom made ladder affair. All of these entail climbing over the pulpit.
Provided your boat is reasonably steerable when going backwards, I'd moor stern to as it is a much easier option in terms of access. The only downside is a loss of privacy but we generally have quite a lot of shade tent up which mitigates that problem.
Yngmar
6 Dec 2012
Gone cruising
Petronella
29 May 2004
Scarborough Marina, Australia
We used an aluminium ladder with plywood sheets attached to it on the rungs between the long sides. We drilled a hole through each long side near one end to take a 1" stainless bar. The bar was installed across the foredeck with one end sticking out to the side. We then slid the ladder onto the bar and secured with a clip.
So we ended up with a passarelle like bow ladder hinged at the boat with the other end on the dock. It worked fine and several other boats copied it. You just need to find a way to support the bar across the bow. In this respect each boat will be different but ingenuity will out!
macd
25 Jan 2004
Bricks & mortar: Italy. Boat: Aegean
Petronella: "thick-walled" tube (2.5mm, maybe 3.00mm?) is strong enough, if perhaps harder to find in some places.
My initial reaction on first reaching Gib was just how many yachts had curvy tubes lashed to their bow. (Actually my initial reaction was "What a whopping lump of rock", but you know what I mean.) I asked a local stainless chap what was best, and he put me onto the thick stuff, which never showed any signs of bending until I hit a quay with it.
jordanbasset
31 Dec 2007
UK, sometimes Greece and Spain
This is exactly the same arrangement I had on my boat, even had it fitted at the same place in Almerimar (I emphasise this is not my boat)
http://www.svsarah.com/Sailing/AtlanticCircle/Images/2006 Almerimar, Passarelle 1.JPG
If you scroll down to the bottom of this link you will see the same picture and an explanation from the owner of the boat. It is not that cheap but it is very effective and the company involved did seem to do a fair few of them.
http://www.svsarah.com/Sailing/AtlanticCircle/SailCostadelSol.htm
