Bow fender..
Neil
6 Apr 2004
Ireland
After an unusually clumsy attempt at mooring, I left a sample of the topsides paint on the pontoon. Since I couldn't rule out any such occurrences in the future, I invested in a bow fender. I've secured it at each end to the toe rail at either side.
But what's the strap with a hole, wrapped around the middle of it for?
Burnham Bob
18 Jul 2009
Burnham on Crouch
i put another small normal fender upright atached to the strap with a line leading up to the bow roller so that the bow is protected for another foot or so just in case the boat rides up over the bow fender
Neil
6 Apr 2004
Ireland
What Little Sister says in #3 surely?
I dunno, I'm not particularly convinced. If you raise it with a singe line, will it be level? Is it not just as easy to adjust the two lines at each side? I understand this is a trivial point, just it piqued my curiosity.
knuterikt
11 Sep 2006
Oslo, Norway
By using three lines you can adjust the angle better. Lifting / pulling at three points give more control.
