Bounty 27 mk 2 propeller advice and vessel dimensions please
Yare.yare.
New Member
28 Mar 2025
Hi all I need a new propeller
Previous one has pitted cracked and changed colour.
I have a Nanni N4.50
PRM 150 D1.5R
1 1/4 shaft.
ANY RECOMMENDATIONS ?
Also I would like to know the following
➡️➡️. Bounty mk 2 aft.
  • Waterline length:
  • Displacement of Vessel:
  • Maximum ahead speed rating:
The size of the propeller will be stamped on the boss. WL is approx 25' Beam 9'6" displacement 2800kgs (approx 6200lbs) The rated engine speed you will get from the spec sheet for the engine.
Rather than guessing contact one of the many specialist propeller suppliers, give them the boat/engine details and they will work it out for you. That way if it is not quite right they are responsible.. Double check it is the original Imperial shaft and not changed to 30mm when the engine was installed.
Wow thank you 🙏
