Dab
In the Nautical Know-how section of the June PBO, there is article explaining how to boom out a jib safely.
Because the article is about safety, as opposed to convenience, speed or short handed, I am surprised it doesn't talk about using an after guy. This is the way I was taught and I think it has a number of safety advantages. Once you have got tension on the uphaul, downhaul and after guy, the end of the pole is fixed in space, so you have full control throughout the pole hoisting part. Because the pole is under full control, you can set up the pole independently of the foresail, so when you bring the foreails across you only have to worry about the foresail sheets without having the adsust the uphaul and downhaul at the same time to allow the end of the pole to come aft. Lastly, if anything happens, like a MOB, so that you have to re-rig the foresail for normal sailing, then all you have to do initially is release the extra sheet. The pole will can then sit there without banging about while you work throught he initial confusion and come up with plan, after which you you can sort it out at your leisure.
This may be over the top for an experienced or large racing (although they are more likely to be flying a spinnaker at this stage), but I would have thought it ideal for cruising.
All of this is very well described in John Goode's Let's Do It Under Sail artical from the May 1992 PBO, with excellent illustrations of the ropework from Dick Everitt.
This is the method I always use. Am I being too cautious? What do other forumites do?
