CAPTAIN FANTASTIC
Hi, I had the same problem and solved it by boring out the metal block and pressing in a stainless steel bush that someone on the forum made to my drawing. (Similar to Tranona's suggestion) I assume it is the normally vertically aligned hole? I had the bush made with a shoulder which took up the wear where the bottom part had rubbed away.
Alternatively you could try Portchester Engineering and see if they could make you a new part.
