swanny
New engine just fitted and engineer put a wire to bridge an electronic path over the rubber flexible coupling. I had a flexible coupling before but without the wire bridge. He told me he does with all his installations. I mentioned that my boat is 'unbonded' and he shrugged and repeated his first comment. Nothing is bonded on my glass fibre boat, AC is not connected in any with DC, even the earth/negative. I do have a galvanic isolator which simply sits on/between the AC earth wire. As far as I can see, there is no chance for AC to mix with DC - perhaps maybe through the shore power charger? Dunno. I have only one sacrificial anode which sits on the prop shaft unbonded to anything else. Should I keep the bridging wire or remove it???????
