GART
The transom is coming away from the tubes on my AX3.
I tried to repair it with inflatable boat adhesive, but it came apart again the second time I used it. I have just bought two-part PVC glue and will try that, other than get all the old glue off and really clean, any other advice? Is it better to repair it inflated? Or deflated? It takes quite a lot of pressure to hold the moulded rubber against the inflated tube, if it was deflated it could be clamped into position, but if there is expansion when inflated would this weaken the bond?
