boat window advice princess 30ds
blobby47
Active Member
12 Jul 2012
kent uk
Hi to all, any advice most welcome. my princess 30 ds circa 1989 ,the plastic sliding windows in galley/forward cabin are in need of replacement, had a guy lined up and all materials sourced,with me to assist (medically retired engineer with leg problems ) alas original guy cried wolf.I can cut sheet poly carbonate ok ,have new seals ,so any advise appreciated,any special tips,,what sealant to use ally frames to boat etc, boat on the water non tidal Medway at Maidstone .
thanks bob
Hi All, I finally bit the bullet and removed lower cabin window frames ,,, all retained by screws from outside ,,it became obvious how frames dismantled once removed.
a local company (Hadlow Marine) webb site gives good instructions on how to and sells all parts needed (no connection)I bought and cut my own plexi glass uv stabilised sheet and cut with jig saw, only one thing to note wd40 a great help to break mastic bond and clean up
