Pyramid
Active Member
The boat is fitted with a Jabsco automatic water system pump, rated at 25psi that delivers 11 litres per minute for systems up to two taps.
Until recently, when you opened the tap the water would run slowly then the pump would kick in, with discharge rate improved a little and run until the tap was closed.
However, now, when you open a tap (mixer type at basin in galley and basin in the heads) the pump does not continually run, but starts and stops three or four seconds later, but starts again after two or three seconds, then stops again and so on.
When I close the tap the pump stops having brought the system to pressure I assume.
Interestingly, if you open both the galley and heads taps then the pump does run without interruption!
I do think that the pressure though is generally low and only improves when the pump starts - as it should of course but not great. You wouldn't be able to shower with it.
The system is not equipped with an accumulator - the Jabsco pump does not require one and clearly - or not, the system does pressurise! It just does not maintain the pressure consistently when a tap is opened.
Filters checked and clean with no leaks across the system, but then again I'm not losing pressure, that's not the problem There are no obstructions across the system and all hoses - half inch - are good.
I suppose the question is this - even though the pump runs, is it on its way out and exhibiting a loss of ability to retain effective pressure upon opening a tap, thus retaining effective discharge pressure. If this is the case I'll replace it?
