Boat water pressure pump
Sailfree
18 Jan 2003
Nazare Portugal
Jeanneau 43 DS used heavily for 13 yrs now and has own shower.
Water pressure pump just starting recyclung to top up pressure every 5 mins.
Don't think there is a leak as auto bilge pump not going at all
Does non return valve in pump go?
Can you get service kits or is it best to replace pump?
I used to have a Shurflo F/W pump, for which the service kit was expensive, and when I dismantled I could never stop the b******d thing leaking again. I replaced with a Jabsco which was only about £25-30 more than the service kit, and that's been faultless for several years. As I have no other way of pumping FW, and any other set up would have cost me 3 figures, I carry a brand new pump as a spare... It's a bit like servicing a toilet, often it's almost as economical to do a straight replacement
Had a similar problem with the Johnson pump fitted to our SO35 last year, bilge dry but fresh water pump started to re-pressure every half hour or so, gradually getting more often. Replaced it with a Jabsco which made a significant improvement, no cycling and much improved flow even though the spec was the same.
Stripped the old Johnson pump down to keep as a spare and found the valves had a bit of gunk around them which was preventing them from seating fully.
