Part One Register
So what do the numbers mean, especially the last bit?
Registered Tonnage - this from Plomong around 2006
Gross Tonnage is the volume of all that is below the Tonnage Deck plus spaces between the tonnage deck and the upper deck, plus enclosed spaces on the upper deck (deckhouses, etc). Usually expressed in Moorson Tons (Volume in cu. ft divided by 100).
Register Tonnage or Net Tonnage (not registered - register) is gross tonnage less the volume of spaces that do not earn, such as engine rooms, bunkers, accomodation, etc., again expressed in Moorson Tons.
For small ships in the UK, it used to be accepted to calculate Register Tonnage as:
RT = (0.45 x L x B x D) / 100
where all measurements are in ft, L and B are overall and D is the distance between the underside of the deckhead in the saloon on the centreline and the lowermost point within the hull, excluding such items as pump wells in the bilges.
So mine is about 9 tonnes?
9 tonnes carrying capacity, but the numbers are nonsense anywaySo mine is about 9 tonnes?
