Sailfree
As we intend to spend more time on boat SWMBO has authorised the purchase of new mattress for our cabin.
Various manufactures and types and thicknesses.
Currently think of changing 125mm Jeanneau foam mattress to a 200mm pocket spring/foam mattress. The next chose is the top internal mattress material. It can be foam, memory foam or latex. Latex is dearest, memory foam can be too hot in summer I am advised so intended going for latex.
For size etc it seems best to get two with zip connection for cabin.
Seen various manufacturers at boat shows but decided to go with the most local one, Millbrook marine bedding, who will visit boat to template cabin (dims vary over length and side slopes)
Anyone any opinion /knowledge on thickness choice (can be 6" to 10"!) topping choice and finally have used Millbrook marine bedding?
Should add the mattress will sit on the existing plastic spring system (about 15mm) to provide ventilation but wondering whether to fit an electric blanket underneath to assist remove condensation. There is no cold water tank underneath as its a DS - only batteries!
