stephenlloyd
New Member
Hi all, sorry if this has already been covered, but I can't find a specific reference to it here.
I have recently bought a yacht with a BMC 1.5 in it, that has never been able to start without assistance from (not happy to admit it) 'easystart'.
Once running it will keep going until I kill it with the standard pull cable. She doesn't sound great, partly I suspect because the air filter is almost destroyed.
Anyway, so to the point, we delivered the yacht 140 miles to where we live, (motor sailed) and the engine was great, not getting very hot etc. But...it did smoke (white) all the way.
About 4 miles from our harbour it basically lost revs and died, and refused to start again. Dirty fuel is the suspicion.
So I changed the fuel filters, (and the water trap/fuel filter housing as it had an air leak) and after eventually bleeding her successfully, she started, once again with easystart. And ran until I killed her, (still smoking white)
I have de-coked the plugs, and tested them, they all glow red hot.
My question is, what is the white smoke most likely from? Can diesel bug cause it? Or is it likely the injectors not spraying properly, or something more sinister, head gasket?
We put fresh fuel (about 180 litres) in the tanks before the delivery, but there was probably about 20 litres of pretty old fuel in there before, so could that be an issue?
Ok......thank you to anyone who has managed to read through this far! Basically, what next? She turns over without firing at all, until easystart is used. And I know its terrible to use, and have only used it a couple times, to check if she will run at all. And want to avoid it until I have an idea why she won't start on her own. I usually glow her for ages before even trying too.
Should I attempt getting the injectors out and have them reconditioned?
Alright, please feel free to ask me to clarify anything, and any suggestions please help!
Thanks very much!
Steve
Thanks very much!
Steve
