BMC 1.5 cooling system rubber end caps please!
Thamesbank
1 Nov 2006
www.thamesbank.org.uk
Please help! I am desperately searching for new cooling system parts.
The cooling system has two rubber end caps holding the heat exchanger in place either end of the header tank (no name anywhere to be found, only BL on the rubber caps). The dimensions are unusual I'm told (62mm, 58mm & 25 mm). The 25mm pipe runs at 90° from the cap.
Any help locating these would be much appreciated. I need two!
VictorII
4 Feb 2003
Belgium
home.scarlet.be
From the photo I can tell it's not the same (Bowman) cooler as on my BMC T90. Is there no brand displayed on the cooler?
But ASAP will be able to help, they have a lot of BMC marinisation parts.
