tonybarebones
Jabsco type pumps... The type without an O ring...
If the gasket on the end plate is defective... heres what I did...
Use bluetack... Clean up the two surfaces of the t pump...
Roll some bluetack into a thinish roll an eighth of an inch or so in diameter and approximately 6 inches in length and apply to the perimeter of the pump cover pressing the two ends together...
Replace the cover-plate on the pump...
With the pump running tighten down the holding screws until tight...
Hey presto a perfect watertight gasket...
It worked for me anyway.
