nimrod1230
Noticed the batteries were way down so plugged in the suitcase generator. No charge registering when monitored and found all three output fuses blown. Replaced and all back to normal? The previous day had been running the generator as using the electric winches putting the sails on for the season and the generator responded to the load each time so presume working correctly to keep up with load. Would this use be the cause of the blown fuses? i can't think of any other reason as all seems back to normal again though why all three would blow(domino effect?) when charging separate banks? I didn't notice immediately after using the winches if the charger had failed at this point. Over to the experts.
