BigART
Is is possible for zinc anodes to be hyperactive?
About 2 months ago, I fitted 4 anodes that I had purchased in South Africa, they were little larger than the usual ones but not by much. On relaunch, the hull voltage was around 0.96 volts, no problem. A few weeks later, I noticed that there was paint bubbling around some of the welded steel pipe through-hulls. I have attached some underwater pictures.
http://www.doitcruise.info/ForumQ_Cockpit_drain_small.JPG
http://www.doitcruise.info/ForumQ_head_pipes_small.JPG
In the eight years we have owned the boat, I have never seen anything like this.
I remeasured the voltage and it had crept up to 1.0 volts so I think this may be the cause. I have now removed an two anodes and the voltage is back down to 0.96 volts.
In the eight years I have owned the boat, I have never had this problem. Has anyone seen this behaviour before? So is it possible for an anode to be too active, too pure or some unusual alloy may be?
Regards
Angus
Regards
Angus
