Bosunof
The symptoms:
1. After sailing and then needing the engine, after starting the starboard lighting circuit fuse has blown (15 amps!!??)
2. At the same time the chartplotter, on a different circuit, goes off line.
3. Batteries still charge and nothing else seems amiss.
Current advice (sorrry for the pun) goes two ways. Either there needs to be suppressors in the circuit, or the regulator in the alternator is kaput.
Have you any other suggestions and remedies, please?
At present I overcome the problems by taking a log reading, switching off, starting the engine and restarting chartplotter again and a pocketful of replacement fuses.
Bosunof
Bosunof
